Exactly the same situation as me. I tried monoflex =too stiff for daily..now Im using CUSCO ZERO 2 big thumb up:thumbsup:
I think MonoFlex is so cushy.
Tein SS don't have height travel adjustment which means when you lower Tein SS you're losing shock travel. I forgot the actual term to use here. This is the only reason I won't consider SS. Are MonoFlex THAT harsh? I can't imagine they are unbearable on lowest setting.
Buddy Club Race Spec is harsh, but they have bad reviews on ht, so I think I'll staying away. Cusco Zero2 is always good and probably gonna be my best choice.
SS does have damper adjustment. Monoflex is comfier than my Flex. Depends on what they expect from coils.
what are the spring rates on SS anyway?
My tein Flex's (on my 5th gen lude) are a great shock but imo are to soft and I spent a LONG TIME testing preload, damping, front n rear bias etc... I've tightened the rears preload up but I still have to much roll.. it dives hard into corners.... even with my sway bar on medium, comfort wise they are great but Im going up to a hevier spring.
n for peoples knowledge to rid understeer and create oversteer you tighten the rear up more than the front..
SS= supershit.
Go for flex.
i agree running tein monoflex on my euro bloody bumpy as but then sometimes it feels too soft.
would it be ideal to preload your springs?
and if so whats the most comfy setting slightly looser springs?
whats the difference between type flex n monoflex?
flex is softer spring rates and valved different to the mono.
all comes down to what you want. you want track then mono > flex > SS
you want street, it's the other way round.
it's like asking yourself "i have a ton of bricks to move, do i use a NSX or my ute?"
