On my car I cannot shift into first gear if my speed is above 20km/h, are you getting locked up while below 20km/h?
no, i can get to 1st gear if you rev match.
it's stationary, as i said at the lights.
You're just having bad luck lol. You seem to get tooth on tooth quite often. I get it about once a month. Do you put it into 1st as soon as you press the clutch down or do you wait a few seconds after the clutch is pressed in before you put it into 1st? Try going into 1st as soon as you clutch in. The spinning input shaft should reduce your chances of getting tooth on tooth. You might wear the synchros a little more, but 1st gear synchros very rarely gets worn anyway because you won't be shifting into 1st while you are moving (at least without doubleclutching anyway)
Yeh sometimes i shift lightning fast into first and thats when i hit a brickwall! :mad:.
I'll give it a go and see if it makes much difference in shifting.
But yeh as i said initially i don't always get it but this week have come across it more often then usual.
Damn i should change my MTF as well but my car is too low to slide jack in and its a pain in the ass to jack the car up using the wheeljack first then hydraulic.
A bit off topic, you reckon it's worth getting ramps?
Isn't it not the best thing to shift into first while car is moving?
