Is the pedal set Auto-only like the CL9 or is that the price for the manual?
I got a aftermarket one.Parrot CK3100 i think,$280 installed.Here's the link.http://www.parrot.com/usa/products/h...its/ck3100-lcd Only problem it doesn't come with cradle so you can charge phone,otherwise:thumbsup:
Pic in the accessories brochure shows manual so i assume price is for manual.See here.http://euro.honda.com.au/optional-extras.aspx
Nice... wonder if the dead pedal and accelerator pedal fit the CL9. :p
Thanks Tony,
Whereabouts in the car did you get the Bluetooth fitted? Does it look neat?
Can you post a pic?
Who did the install for you?
Cheers mate,
Mike
bump!
Have checked the sports pedal kits from the CU Euro, to see if it will fit the CL, and so far, so good!
Havent checked the dead pedal as yet, but the brake, clutch and accell are all go.
You have to install them via removing the old rubbers off the brake/clutch, and pop rivet the newies on, they come with new rubber inserts, and the accell just pop rivets right over the top.
Hope this helps.
