so i had a poke around tonight
found one one of the bolts holding my intermediate shaft was 3-5mm out so i tightened that down, seems to have lessened the violence of the shaking but somewhat still there
confirm that my passenger side tie rods somewhat stuffed, the movement seems to be coming from where the outer and inner tie rod join instead of the ball joint at the end of the outer tie rod
grabbed the tie rod boot where the inner and outer tie rod join and it gave no movement while just holding the outer tie rod seemed to give movement
and how much play should there be between the passenger drive shaft and the intermediate shaft? i seem to be able to move it left and right about 3-5mm, that acceptable at all?
both drive shafts seem to rotate fine without any strange noises so the whole things still got me stumpted
bump anyone able to answer my play between the intermediate shaft and driveshaft question?
Did you ever sort this problem out?
nope still there
changed drive shafts
changed half shaft
retorqued engine mounts
4x114.3 stud conversion(so different bearings and knuckles)
still there :(
Sorry to hear that. Must be frustrating when you can't get to the root of the problem.
sure is.. next step is rotors(got some brembo's to replace the rda things on there)
i'll get there sooner or later hehe
