all it has is a thread at ethier end but top bit has a rubber gasket and pivot head, hope that helps, what are u after?
does it neccessarily to bolt to a rubber gasket, becasue mine dont
I just got this off of an EM1, the endlinks have the rubber gasket over the pivot joint for a reason (so no dust/dirt can mess with the movement) they come as one piece
does anyone know if a EK9 rearsway bar setup would include the rubber gast\ket too?
It does, as should all, it would be a matter of time before the dirt and grit on the roads would compensate the movement and fail at that point
have a look at JDMConcepts pic on the forsale area of the EK9 sway bar kit, you can see it :)
ask bowzer at modproject he sells them endlinks pretty cheap...
im pretty sure them endlinks all have that rubber cover to cover up the ball joint... where the rivets are though (the TOP of the endlink, ie where the sway meets the endlink) there should be a plastic shield to protect riveted part...
ek1s endlinks look like mine...
yea, mine are covered, I can only image the ek9 would have thicker endlinks and a difference thread on the top
