Nope purchased from a dealer...6 month warranty from dealer as well..
Mmm, cant be normal, where is the water coming from??
I had given it a quick was on Saturday at the local car wash (just used the high pressure spray, no brush of course don't want swirl marks!!)...does it collect water anywhere? I was thinking that maybe its not draining correctly through the channels therefore there is a small build up of H2O that would start dripping...
Left door thankfully doesn't rattle have cranked it up, although i am thinking of changing the front speakers as they are crap..may add some tweeters as well.car sits level as far as i can see.
Busy at work today will try and get it booked into a dealer this week
its normal.....its a condensed water coming from your aircon unit...its coming from the evaporators drain tube..so nothing to worry about...
cheers
Hope so!!
Sorry to drag this out, but would this still happen even if the aircon hasn't been used? (as in this case)
yep tried the aircon yesterday works fine
Swirl marks from the brush? lol. Scratches maybe... If you don't clean it out.
lol my right side and left side isn't the same height too
^^ which one is higher? is it the driver side??
the drivers side is lower
yep same. I think it's cos of the steering column.... so logically, any car would have this issue.
09 Sport here - there seems to be a rattle on the passenger side area? not sure if it's the seat belt at the lower end near the seat that hits the plastic trim of the seat or what? and then the centre glove compartment? I've got nothing in there but a distinct knocking sound that comes from it on bumps? Common issue?
