I have an 06 model and the clutch creaks. Don't know the cause.
have you euro guys checked the SLAVE cylinder yet ? it can be dry from lack of lubricant and give a few different noise and or feeling symptoms.
so what is the best way to describe in tech terms to get it fixed under warranty? Creaking clutch caused by lack of lube on master cylinder?
BS problem is coming back again!
Just tell them your clutch is creaking and ask them to check it out.
Or resign yourself to regular lubrication with Silicon grease...
I've gone through 3 master cylinders via warranty and I'm still getting the problem, was a 3P manufacturing defect.
so were do i apply the silicone grease to?
on the CMC or the spring?
I used valvoline multi-purpose grease and applied it on the folk of the gearbox where the slave cylinder is and..... it stopped it.
thanks aaron, i did it, didnt really help so i booked it in for service, i just hope they replace it instead of lubing it up again
Hey guys, sorry to dig this up,
I have the exact same issue, and it drives me nuts,
Clutch works fine, it feels like the spring is the cause as it sounds like kicking an old bed when you press it down,
Is it hard to get to the clutch spring? and how much would a clutch spring be from Honda?
In regards to the slave and master cylinder lube, where are you guys spraying silicon spray? i'd prob use lithium grease also..
Cheers
Brendan
