17x9 +38 up front.
cr kais. dish rims can be different as offset and width do not neccesarily indicate clearance.
It should. I have a 50c coin width of clearance from caliper to spokes without extended studs and a 5 mm spacer
Before the 17" I had 18x7.5 cr Kai +48 offset which cleared (just) the calipers with the same spacer and extended studs so I'm sure ce28 will. Their quite concave once you get to 8" with with some decent offset
old set up Cr-Kai 18x7.5 +48 all round with a 5mm slip on spacer. the spokes ran flat against the caliper with like 2-3mm of clearance if that.
current set up Cr-kai 17x9 +38 with the same 5mm slip on spacer. same clearance as above close to the hub, however as the spokes go out toward the lip, it arches out giving more clearance from the middle of the caliper (where "spoon" is printed).
with the 17x9s i could just clear it without the spacer, but i was running extended studs, so the spacer was required to fully thread the wheel nuts.
hope that helps fellow ep3rdian
would 18x8 +15 and 18x9 +10 work on ep3? offset calc says theres more inner clearance but extending 43mm and 60mm from rear.
stock height
would 17x9 +38 on a 215/45 profile tyre work on the rears of an ep3, how much camber would i need to clear the trailing arm?
