Originally Posted by
TODA AU
			As you can see from the dyno day results, your car is putting down the average power for a H22A. Some are better, some are worse. Had the dyno day been held on our dyno, chances are the outputs would be 10kw less (based on your results). Numbers aside, the car is going better now & has 5~6kw more in the peak power & around 10kw @ 5000rpm. this will translate into faster smoother driving. Whether 1 dyno reads higher or not doesn't really matter but the trends are the same.
