do the rear sway help heaps?i got rear strut already
yeah definitely worth getting
should have got rear sway before strut
although baring everything up in your car is awesome!
HMM, beaks is kinda tempting eshhh, but i should get rear sway first hey? =[
but geeze cusco rear sway is like 450 ish.. no money for that lol =[
yea, does ultra racing makes em?
i believe UR RSB size is 19mm whereas cusco's is 23mm.. does not f!@k up the endlinks
where invest in cuscos then huh
after my brake upgrade i guess...
cuscos 23mm wont fk up endlinks because it have the proper reinforcements
if you getting UR which i have got, get 16mm will be fine with the endlinks
16mm is enough for street use i reckon, the car will be harsher
EDIT: UR now provides reinforcements for the 19mm, 16mm i think you have to get them seperately, not too sure but will be fine without
should get reinforcement.. even the oem 11mm has reinforcements
yeah i got them but been using it for a year without its fine even with some spirited drives once a while.
