If you're gonna run at those low offset and wide specs, you gotta be low and probably a bit of tucking with the tyres with the guards for it to look right.
You will also need to run some negative camber to get the rims to sit inside the guards - which means you'll be replacing tyres a "bit" more regularly.
BTW, flush looks great! :)
Hellaflush is too much for me.
