I'm on stock height, and I got my guards rolled. I'm running 18X8.5+35. Would 225/45R18 fit with no problem? I wanna run bigger tyres...
it should be no problem, u got ur guards rolled too and stock height would fit those tyres fine
use this http://www.miata.net/garage/tirecalc.html
compared to ur old setup, 225/40 would raise ur car abit higher than stock, going 225/45 would raise it higher, due to the total circumference of the whole wheel being larger than ur stock
Considering my current wheel setup 18X8.5+35 with 215/40R18. I want to add spacers, what would be the perfect amount without needing to camber? I've also rolled my guards. I'm considering 15 or 20mm? Would 20mm cause to my problems?
Can you guys help me with these question. Thanks
Car Model: FD
Front Wheel and Tyre Size: 17x8+32 and tyres ???
Rear Wheel and Tyre Size: 17x8+32 and tyre ???
Suspension: ???
Guard Modifications: ???
Issues with Setup: ???
Car Model: FD
Front Wheel and Tyre Size: 17x9+28 and tyres ???
Rear Wheel and Tyre Size: 17x9+28 and tyres ???
Suspension: ???
And 1 more noob question. Different off set we will get different looking. Is it true? The wheel 17x9 which offset will you choose? +28 or +38
You would be fine running 17x8 +32. I Run the the same offset and width with 225/45 tyres without too many problems
Suspension: coilovers
Guard Modifications: rolled guards
Issues with Setup: scrubbing guard lining on bumps
As of the 17x9 +28 I'm not too sure but i assume you would need a fait bit of camber to fit that
Car Model: FD
Front Wheel and Tyre Size: 18x8.5 +37 and tyres 225/40R18
Rear Wheel and Tyre Size: 18x8.5 +42 and tyre 225/40R18
Suspension: Stock
Guard Modifications: None
Hey guys wondering if the wheel setup would fit without any scrubbing or any problems?
Thanks in advance :)
Car Model: FD
Front Wheel and Tyre Size: 18x9 +32 and tyres 225/40R18
Rear Wheel and Tyre Size: 18x9 +32 and tyre 225/40R18
Suspension: lowered on buddyclub coilovers
Hey guys wondering if I should get 225/40 tyres or 215/40 tyres? I will be rolling the rear guards soon. Will I run into problems with the 225/40 tyres with this setup? thanks :)
