what you got?
fd2r uses a map sensor which is located on the intake manifold while our fd2 uses maf on the intake pipe hence theres no opening for the sensor on the gruppe m.
also...
found on vtec temple.Quote:
One thing i can confirm is that our rides are VERY sensitive to modifications at the low end. The MAF sensor is also very sensitive and has to be exactly the same diameter where the MAF sensor is located on the intake track.
intake pipe for fd2r is 3" and our fd2 is 2"
so most likely it wont work
I've got Buddy club N+ Coilover for sell kekekeek
I just bought new rims... i shouldnt be spending any more money...
Unless some one want my Blinging 19"s hahaha
K20z2/3/4 all use MAF sensor, the reason you are getting a CEL because you've removed it from the air stream, now the engine doesn't know how much air is going into the cylinders and therefore does not know how much fuel to pump in. The ECU is smart enough to go into a limp mode when the MAF reading doesn't make sense. So either find a way to put the MAF into the pipe, in which case it still might not run as well cause its very sensitive (atleast no CEL?) or find an intake that has a mounting hole for the MAF. The MAF sensor housing also houses the Intake Air Temp sensor, so that needs to be in the air stream too.
That makes so much more sense.
Didnt think a fd2 didnt have a MAF.
Even my fd1 has one and the injen CAI has a perfect spot to mount it on.
Hey Guys
im parting out everything on my car.
let me know if you need anything parts? thanks
wow..
would u sell ur ducktail? if so, pm me how much u'd like for it plz
sorry,
cant sell that is it bolt onto it.
damn =[
no worries man.
