Originally Posted by
ewendc2r
Ok so maybe someone like Adrian or Chris or someone else with extensive knowledge can step in here but my belief was:
Harmonics come from the crank, not the block.
Yes the B20 block comes with 84mm but it doesn't come with the 87.2mm crank does it!
Yes, if you want to do it properly, you should get the main's align honed ?? (is that the term?) where they ensure the journals are true and straight. Then new bearings.. ADDED COST / EFFORT
The difference in capacity is a huge 40cc ...
I don't drive my engine on the track at lower rpm where the said 89mm develops more torque, and even on the street if i want the power i change down a gear. Why? To take advantage of a freely spinning engine.. In fact, the rod/stroke ratio and rod/bore ration is inclined to producing peak torque higher in the range meaning (again because HP is a product of torque & RPM) the range i use the motor in, it actually develops power higher where I am using it rather than tapering off..
ITR (again) is fully counterbalanced ... It can be lightened (some say around a kg max) without affecting high rpm harmonics / vibrations. Remember heavier = better vibration damping to some extent however at cost of engine response. Thus my question about weight of 89mm vs 87.2mm..
Look, if I could get a tall deck block, I'd just get a 92mm crank and call it a day with 84mm bore but thats when costs start to ramp up...
I'm not trying to start an argument but it just seems in race motors that the 87.2mm crank has yielded more reliable high rpm performance and with similar power levels (area under the graph, total accelerative effort)
