What's what I do with mine. I spray in to the master cylinder while pressing down the clutch. Keeps the creak away for a few months.
^ +1 if someone could take pics / use paint and make circles around the areas that should be lubed that would be great.
Go look at your clutch pedal. There is a rod that goes from above the clutch pedal into the firewall. Where the rod goes into the firewall, spray there. Easy.
Here is a generic pic:
http://www.lieblweb.com/tacoma/Mecha...dal/Cotter.jpg
See where the rod is just to the bottom right of the green arrowhead? It goes into the firewall where the black ring is. That is where you spray. It is not black on the Euro, but it is still a ring where the rod goes into. Same thing.
Here is another pic:
http://www.automotivearticles.com/up...h_pedal_1_.jpg
Look where the arrow labeled "rod adjustment" points to. Follow the rod to the right in the pic into the firewall and you will see it goes through a ring. Spray into the ring.
Hectic, Great work from aaronng once again :thumbsup:
Can we use any kind of lube? or does it have to be silicone spray?
Hmmm, Tried to give this a go, but couldnt really see the part of the car where it goes. i tried looking for the things in that pic, but there isnt much room from the top. I Jacked it up and still had no luck :(.
Im guessing we go in from under the car? and it would be the back half of the engine bay, but there isnt anything similar to the pics.
Thanks, That was alot simpler than what I thought needed to be done :)
Creaking clutch gone, lets see for how long. Thanks Aaronng for hectically quick reply LOl.
Even a lube stick is good.. it looks like hardened vaseline.. works great too.
