what rails? will they fit any seats?
BTW the bride rails for DA only fit side mount seats...meaning ones u fit on the side plates then on the rails...so the tradition recaros for dc2/5 won't fit
EG/DC camber kit will fit...
maybe u can custom those rails to fit..but would be a waist of money...u mite as well get someone to do some custom rails for u then or mod ur stock rails to fit....
Hey,
What Exhausts are people running on there rides i am looking at a catback i was looking at this. http://lsdmotorsports.com/merchant2/...MA,MT,NI,SU,TO
Or Are there any good places i should consider in Melbourne?
Hit me up with Any info.
Cheers.
heya guys, just a technical engine and transmission question i dunno if anyone could answer this but could i use my b18a1 gearbox with a b18c2 long motor? hit me back boys/girls thanks man :)
yes you can. but you may want to upgrade your clutch depending on the type of driving you do..
The gear ratios aren't ideal though..
yeah the DA gear ratio suck big time...specially on track!..if u stick to same box..suggest u get different final gear
ok thanks fellas xD might aswell move from b18a to b18c2 cause b16a's are crappy. i like my torque so maybe thats a better way to go.
Hey,
Battery corrosion on positive terminal cant get rid of surely other people hear have had the same problem on this model ? Any ideas Ive got new terminals, corrasion pads, vaseline, cut down and soldered the wires for tight for a good fit. But it keeps comming back i need a fix...
