yeah simon. though clutch fluid is not expensive from honda.
thanks for the help. been stalking this thread. just bought my euro
it creaks when i push it down at the very bottom.
but at times it doesnt do it at all for instance when i wake up n get outside to warm the car, leave it untill warm revs drop to about 700rpm, then its gone
but the creak sometimes happens when i just cold start n drive normally. and i do rev match as well
Yea sounds like master cylinder, I had a similar thing happening, it will get progressively worse.
No such problem with the facelifted version... maybe you should change with the FL euro parts.
I know the facelifted version suffers from the creaking clutch as well (if by facelift you mean 06+ CL9, and not CU2). Whats an FL euro part?
FL euro means 06 onwards CL9.... CU2 is a new car already.
why not sell the CL9 then get CU2? lol that is my answer since I have my Cl9 for 3 years now
well i rang honda today about a service, generally chatted with him but the clutch issues in the euro. He did begin to say that a revision was made later on, but then later wouldnt confirm it lol.
Anyways, got a spray, gonna try to temp fix it.
thanks for the pic aarong,http://www.ozhonda.com/forum/showthr...al-Euro/page45
any advice on how much to spray? thanks.
Edit: nm, sprayed a bit. Will take it for a spin. I hop this time is lasts for more than a day :(. I have found when the car or weather is cold, its ok. Only when the drive gets longer or hot temps is worse.
I will be getting my cylinder replaced sometime next week, my pedal has been the worst I've used. Hopefully it fixes the issue! :D
