why cant you use the 4wd civic/wagonvan trailing arms and rear hub, and the crv box/rear diff etc, then just get custom drieshafts made up?
would be easier than cutting and shutting the crv arm
trism, a 6th gen. 4wd civic is just a fantasy at this point.
Honda DID make them.
I think we are just slowly chipping away at confirming relevant part numbers for the bits from Honda which will bolt on.
Given the pace it's probably never going to happen, but that's not to say it doesn't deserve a little bit of effort.
Nick.
no no, im talking about CRV gear into a 4th/5th gen civic
even if its just the box so we can use a b series rather than a d series
sorry. no idea.
do the crvs not use a transaxle? the box, front diff and transfer case are all one unit?
Yeah they are? But it still wont mate with the D engine.
Oh in my previous post i said D transmission, maybe that was the confusion, i meant engine. (edited)
lol
if you read what i posted up there, i asked about the crv box so i can use a b series engine, instead of a d series
Ha, sorry. I misread it. I went into a spiel on the previous page on how lame the CRV clutch actuated dif is, I'm not sure if the clutch section could be removed but you would need to upgrade your rear driveshafts, those things really are tiny.
On www.hondacivicwagon.com there was a member who put a B series engine into his 4wd wagon, but it was a lot of work.
Searching for random cars, found this... could be of help....
http://www.carsales.com.au/used-cars...d=11D1C098C93C
Could be used as a parts car.... 4WD civic....
Good luck....
dunno if this has been posted but might be usefull.
don't even know if it will help but a picture paints a thousand words:
http://videos.streetfire.net/album/4...ic_1302996.htm
The dif's welded solid to the car, i wonder if they have problems with that.
