Weapon-R, more expansive, more well know brand.
PLM, HYTECH design, more substiantial, but harder to fit a cat, cheaper.
Just buy Toda.....
U could try asp if u want...
If you are willing to cut into the stock/manufactured cat back to fit a cat then I'd go for a hytech design (which is the PLM) over the Toda. More bang for your buck. It seems that hytech is all the rage in the TSX scene right now over in the States.
From that review, the Hytech doesn't give you space to install a cat and you lose some mid range for very little top end when compared to WeaponR. Based on that dyno, I'd pick WeaponR because I get to keep the cat on, avoid CEL and pass pink slip inspection every year (NSW).
In the end, the Hytech is a race header and if you had an engine that would rev to over 8500rpm, then only would you see the power gains at the top end. On the K24A3 engine, the RPM limit at 7300rpm is just too low to get into the RPM window where the gains are.
I have a JTune Exhaust and it works flawlessly you can't even hear it unless u give it a little squirt
you have to weld a cat to the weapon r's straight pipe. I can't be bothered with the hassle so I might just get the comptech or xforce. What do u guys rekon about the x force header?
just ordered some weaponR, would see how it goes
Maxim works is another header...
I have x force header if someone wants.... Or so I think it is... 2 piece, bolts to stock cat...
