Don't leave the manual and logbook in the glovebox.It seems to be too heavy to be left in there.
I'm noticing this with my 06 euro auto. It settles down after a few minutes so I thought it might be "normal" with the colder weather now. Maybe I should take it in to the dealer for a look since it's under warranty until October :confused:
There are a few intermittent rattles around the place too. Can those be fixed under warranty?
Whilst it settles after a few minutes it still feels wrong. Not only does it feel rougher but also louder at idle. I suppose many people don't notice it because they may drive for a few minutes before they come to a stop and by then the car is warmed up and idling correctly. However, i usually have to stop at a traffic light within a minute of leaving home and this is when I notice it most.
Let me know how you go with your problem. I've told my dealer and they want me to leave my car with them overnight which i can't do just this moment. Where are you located?
Most dealers will fix rattles, especially if you had purchased the car from them. Are you going to purchase the extended warranty? Probably a good idea. Or atleast use that as a bargaining tool.
I'm in Adelaide. I'm the second owner, just bought it about 2 months ago in a private sale. It's been great, but just noticed this rough idling for a couple of minutes after starting in this cold weather. I'll probably enquire at my local dealer about it. Let us know how you go too.
Sorry i have to ask rough start from cold.
Do you park it outside in the vast forces of nature?
And by rough, can you elaborate a bit on how it is rough?
Cause i know mine is rough on cold starts [ in garage(not as bad as outside) ]or outside) but within a few minutes once the engine is slightly warmer it is fine.
It's parked in a garage but I doubt it's much warmer in the garage in the morning than outside. The fact that it is rough for only a few minutes then sorts itself out made me think this is *normal*. Like Unity said it's a strong vibration. It's not horrible but it is a definite departure from the normal very smooth idle where you can hardly feel the car is even on. Reading other comments in this forum it might just be normal, I have no idea. I might speak to my service dept and see what they say.
with outside you get moisture in the air which can create frost.
whereas in the garage your less likely cause its not directly in contact with wind
Hello,
Had the CU2 for 2 months and the following problems have occured.
1. Pinging (mild but noticeable)
2. Horn fused.
3. Cruise Control unable to "SET". It can be turned on/off but cant set speed regardless whether travelling at 60, 80 or 100.
lingamair - i'd speak with your dealer principle for some answers mate.
