Southside Honda said the parts will be arriving on the 23th Nov. They told they got one from Melb. still waiting for the rest to arrive.Quote:
if the worst happens and we don't get the parts from Honda, we can still drill the holes and wire everything up on the day. putting the parts & bulbs in is a piece of cake.
I rang sthside honda this morning, they told me they are expecting the parts to arrive in the next 5 days.
are there any thing I should prepare or bring on this Sat DIY day??? :)
Hi guys in Brisbane...... put take pics as u guys go about installing the lights..... a write up of the pics would be nice too.... if its not too much trouble..... share the knowledge..... :D so us down at melbourne might get together and have the lights done too...... appreciate it.....
cheers...
hi, hope this can help~
http://hondafit-web.hp.infoseek.co.j...p02/lump02.htm
What we need:
1. Socket x2
2. Light blub x2
3. wire (1m is more then enough)
4. female speaker plugs (1 pack)
5. sticky tape
I know someone will bring a drill, and i will bring a vacuum machine just in case
You need to cut a short peice of water hose (50cm) to attach (tape) it to the vacuum hose so that you can insert the smaller hose into the hole you drilled to suck out all the plastic bits inside the light.
6.) 6x solderless connector. (kmart $1.99 a pack of 3)
Ill be coming on the 27th, but I dont think i will be doing the mod cos I hvan't ordered my parts. I just finished exams on saturday. Thank god they are over
as i said b4, just get the holes drill & cables wired up. when the parts arrived, it's a matter of putting the bulbs & stuff in.Quote:
Originally Posted by kuso
you may try to call Sthside Honda just in case they ordered a few more.
do a write up pls so ppl in Melbourne can have a similar metting as well
true hey... good idea. I will get he holes drilled and stuff. Where abouts do I go buy the wires? that are needed in that list htat was posted eariler in the day
