And my answer is still the same, use the search function. Why should I type all that out for you, when it is obvious that you are not after the information for its usefulness. :)
Errrrr im actually after the information that you claim to have.....its simple, If you dont use Honda's OEM FEO then what IS the best?
The post states "What brand of oil"....therefore im just asking to list every brand of oil that you know which is better than the OEM FEO and provide me the pros and cons so i know that you're not pulling it out your arse and hence it would satisfy my knowledge and leave it at that:)
everyones going to have their own opinions on brands, and as mentioned before really depends on your engine/condition etc. if your looking for something like feo, i recommend royal purple 10w-40. which is what im planning to use next. Pros so far: its synthetic + will have to exp if there is any difference at all, Cons: will find out if any. in the end, engine oil is engine oil it does what its ment to and not the only requirement to keep your engine in tip top condition.
I don't need to prove anything to you. But if you are after that knowledge, these are only a short list of the oils that are better than FEO in protecting your engine: Castrol Edge 5w-30, Edge 0w-40, Mobil 1 10w-30, Motul xcess 5w-40, Motul 300V 10w-30, Elf Exellium 10w-30, Excellium 5w-40, and the list goes on. These are all Group IV and Group V oils with the exception of Edge 5w-30 which is a Group III. Group III still protects almost as good as a Group IV but does not have its resistance to harsh operating conditions. Of course, this list is only for Hondas as your R32 requires a totally different viscosity which makes this list of oils unsuitable for your engine. :)
In that case you can start doing your homework by writing up Castrol Edge 5w-30, Edge 0w-40, Mobil 1 10w-30, Motul xcess 5w-40, Motul 300V 10w-30, Elf Exellium 10w-30, Excellium 5w-40 pros and cons
"Its only a short list but the list goes on".....
Now you're involving R32's engine oil?....forget it dude.....you know JACK S#*T about oils, if you dont want to prove all engine oil brands and their pros and cons just say so and leave it at that.
the obvious pro of a better oil is "maintains thin oil film on moving surfaces under high pressure, does not break down under heat and pressure as quick" and the con is "more expensive". That would be the SAME of ALL the oils listed there except for Edge 5w-30 that I mentioned had a con of not lasting as long as the Group IV oil under heat and pressure.
Anyway, I have entertained him enough. If he does not have anything to contribute positively to this forum, then he is not welcomed here.
this thread is a very useful one to us all. The behaviour that has been going on in here will not be tolerated. All have been warned.
anyone use martini oils before what u guys think of them?
just bumping this thread as i do not want to open a new one...
currently engine is running on 170,000kms and needs a servicing, and decided to do it myself, the previous service the mechanic had used a motul racing oil, and i was wondering where i can buy this from as i liked the effect it did on my car, what do u guys recommend? and the engine is leaking a bit as well.
and also do i buy the oil filter from honda?
cheers
