Originally Posted by
82911
The ideal is to design the piston dome and chamber roof to match each other for profile.
The welding of quench pads is done to reduce chamber size and add compression, it can also hinder flame propogation if it is not done with consideration of piston dome profile.
When i am designing a chamber shape i will tend to profile shape the piston moreso than the chamber roof (head). This is not because one is better than the other, just that removing the obstructions from the piston dome also reduces the piston mass, so it is win, win.
As for chamber modification, I would bias the design of the chamber to assist flow past the valve seat and across the chamber floor more than look for ways to bump the compression up with mods to the chamber.
Cheers Greg..
