mooshie said he runs 80a with no problem, 80amp sounds right to me.
I believe that constant cranking will blow an 80a mega fuse.
normal use will be ok i think.
no...
ok so constant cranking will blow an 80 Amp but a 100Amp is too much
You want the one that will blow when pushed, not the one that will never blow....
If it never blows, why need a fuse?
Isn't the fuse purely for short circuit current? The amps being drawn by the starter should be pretty consistent
The fuse is there to protect the cable in the case of short circuit.
0 gauge can run 150amps all day. But if there is a short circuit ie the insulation wears through and it grounds on the chassis, it'll flow infinite current. The wire heats up, melts the insulation, and causes it to catch fire, burning your car to the ground.
So we install a 140amp fuse. The starter wont draw this much, and if the cable does happen to short out, it'll pop the fuse instantly.
You have the fuse mounted with in 20cm of the battery, so that you only have 20cm of unprotected cable.
