I'm not sure of the exact details, what I meant is that a thinner oil gives a better fuel economy during the actual test the use for CAFE standards.
If a manufacturer fails to meet the standard they can face big fines. During one of the test the lower weight and shear friendly oils perform better, at least it's what I've heard. Let me know if you know differently.
the 10 psi thing.
I'ts not like its a set it stone rule.
http://www.positivespin.us/MotorOil.htm go here to read part 8. Lol taken from the exact same article as the supratech one.
I'll do my best to summarize
although the article is much better,
It's completely to do with your oil relief valve, and its probably safe to say its a theory.
I dont know exactly when it opens on a b16a, I did a search and found 70-75 :/ i dont think its correct, if anyone knows please tell me.
Well I expect it to be at least 80 when it opens, but lets see anyway. Lets say you have 15 psi per 1k rpm.
1k -> 15 psi
2k -> 30 psi
5k -> 75 psi
6k -> 90 psi
8k -> 120 psi
Oil relief valve opens before 6k and reduces flow drastically, the result being your engine revs from 6-8k with reduced lubrication
if you have 10 psi per 1k rpms
1k -> 10
4k -> 40
6k -> 60
7k -> 70
8k -> 80
the result being constant oil pressure and flow figures right up the scale
and I guess hondas with vtec deviate at the lower part of the scale, the reason being that extra oil pressure is required to engage vtec, right? after vtec engages pressure drops slightly
