hey man, where's the best place to buy some VTEC fluid? I suspect my gfs vti sedan needs topping up coz we can't feel the vtec kick in, do you know if meekong spared in canley keep it in stock?
Stop trolling you noobs.
OP just check oil level and if that's sufficient check if there's an oil leak at your VTEC solenoid.
Yeahhhhhhh lol
May as well do compression test too
^ true dat
1) Make sure oil level and oil pressure are good
2) Make sure car is at normal operating temperature
3) Make sure there is no check engine light
4 Make sure wires/plugs are tight or wired correctly
5) Make sure vtec solenoid is clean
6) Make sure you have a vtec enabled ecu
Hopefully you can get it sorted out! Good Luck
im suprised this thread is still open.......
Btw here is a couple of things to check out
1. Any vacuum leaks on the intake arm or around the air box
2. Failing / failed TPS
Both can alter the "feeling" of VTAK ( serious)
B SERIEous GUYS! this guy really wants help.
are u using 98 ron?
You expecting VTAK to kick so hard that you actually get forced back into your seat? o.O
Personally I think tell her to pull harder
