Buddyclub P1 SF 15x8 +32 4x100 now available in gloss black!
$900 incl gst ( set of 4 wheels )
http://farm4.staticflickr.com/3786/1...0f56c320_c.jpg
Spoon style FD civic manual side mirrors $120 incl GST ( May fit other cars too with custom work )
http://farm3.staticflickr.com/2859/1...02d52227_c.jpg
Mishimoto K swap EG and EK radiators $440 incl GST
Lifetime warranty !
http://www.jdmyard.com/image/cache/d...33-500x500.jpg
Want a quality custom exhaust done on your project build ?
Contact us for more details.
https://fbcdn-sphotos-g-a.akamaihd.n...43333075_o.jpg
Hardrace is proud to be releasing Version 2 of its popular Front camber kits for Honda EG,EK Civics & DC2 Integra.
Version 2 is designed specially for lowered vehicles. Camber is now adjusted from below, the new locking plate keeps camber settings true, whilst providing extra strength and rigidity during high speed cornering loads.
Hardrace customers with Version 1 camber kits, can now upgrade to version 2 without buying a full kit for $88 incl GST Per pair
https://fbcdn-sphotos-a-a.akamaihd.n...85467932_o.jpg
https://fbcdn-sphotos-c-a.akamaihd.n...75467585_o.jpg
K-tuned 3inch Oval Tube Catback Exhaust DC5R/DC5S/DC5 base
$950
K-Tuned RSX Cat-Back Exhaust Systems have been developed to offer maximum overall performance and excellent fitment, something that until now has been quite difficult to accomplish on the RSX chassis. With several exhaust systems currently available for the RSX, we already know that 3" piping reduces restriction and offers the K engine significant power gains, especially in the higher rpm range. The problem with most RSX exhaust systems has been fitment because standard 3" round piping under the RSX chassis hangs way too close to the ground. This has forced some manufacturers to sacrifice performance by using smaller tubing to compensate for the bad ground clearance. The key feature of the K-Tuned RSX Exhaust System is the unique 3" oval tube mid pipe, which completley solves the ground clearance problem and maximizes exhaust flow. There shouldn't be anymore scraping on driveways or speed bumps because the 3" nominal size oval mid pipe actually hangs at the exact same height as the factory Type-S exhaust.
The system is a direct bolt-on for all 02-06 RSX Type-S models but will also fit RSX premium/base models that are using or switching to a Type-S style header. Note that the entry to the mid pipe has an extremely short section of 2.5" pipe that quickly steps back up to 3". This is necessary because we wanted our system to bolt up perfectly to the stock Type-S header as well as any aftermarket headers that maintain the factory connection point. If you have a turbo setup or an aggressive all motor setup you can easily cut this transition off and join it to your down-pipe or header. The rear section includes a resonator and a fully polished stainless steel muffler with a 4" double wall slash cut tip and we also include all gaskets and hardware. For anyone who has questions about sound, keep in mind that this is an aggressive, race inspired, straight through exhaust system so it will make some noise. This kit was not designed for the average grocery getter RSX.
http://k-tuned.com/images/ktd-rsx-cbe_01.jpg
