i would assume you would get to 400 hp less safe with e85 due to the fact that it would burn slower and need more timing for the same power. which means more cylinder pressure on the up stroke and at tdc. uless you go for higher boost so you can run less timing. which is the recipie for higher power stock sleeves anyway.
