OMG just trash the ****ing car
And the first trolls. THUPER!!
if anyone has had the same or similar issue of coming and going spark can you please tell me :(
nice cluster
i like it. easier to read
I don't know if it's related but in my cxi when I changed to a cluster with tacho it wouldn't read properly.
Tacho ran slow (about 1000rpm lag). I put back the original cluster and just use an RSM. Much better!
Please ignore these two as I'm fairly sure they are from another group I'm on.
An how is it rude? I was nearly pointing out the fact that I had already said it.
As for the tachometer it's back working again.
It was already working before the swap.
Doing the swap from forums was due to no one I knew wanting to help. So to the forums just like many others.
Hence why I'm back on the forums to ask for help to fix my unique problem not only to help me but hopefully someone else when they google the issue they're having.
I'm stripping out the entire loom tomorrow and checking for any breaks in the loom where a stray wire may be loose and causing a short. If nothing then I'm going to check and make sure that I have every single wire perfect and spot on.
Also please refrain from posting if you're not going to help and just creating banter. It not only irritates me but takes away from the main issue and shifts focus from helping to being a toss
And dyinghearts has got to be sachi
