ok, i'm resurrecting this thread...............
i understand that a stock and/or small size diameter rim (relative to the proportion of the car) has higher tyre sidewalls (profile) in comparison to a larger aftermarket sized diameter rim (relative to the proportion of the car) has lower tyre sidewalls (profile).
am i correct to assume that a stock and/or small size diameter rim is has less rotational mass than a larger size diameter rim therefore a stock and/or small size diameter rim will efficiently transfer power into the wheels (less rotation force & less stress).
which brings me to my question:
what size wheels are best on a circuit track? ie wakefield?
I have a set of stock 15x6 (195/55r15) and also a set of 18x7.5 (215/35r18).
which of these would be the ideal to run a lower time?
The larger wheel with low profile tyres would be effective on the corners? would it not?
And the smaller wheel with high profile tyres would be effective on the straights? would it not?
What is the compromise? Which set up is best for this use? And why?
