so going to do that in my euro! plan is tomorrow and tackle it and change all the interior lights
knowing how retarted i am, i will prob snap them off. fingers crossed
finally found some leds and got them installed, will post pics later on.
all i can say its bloody bright and bit of fun
I did mine on the weekend, looks sexy! White LED is better than the stock yellow.
made the mistake of buying single smd led bulbs... poor light output, can't see at all....
http://img212.imageshack.us/img212/8159/311led29ih4.jpg
here some pics of my done job, bit of fun and def more brighter
(sorry for poor quality, was taken with phone)
http://i413.photobucket.com/albums/p...3122008427.jpg
http://i413.photobucket.com/albums/p...3122008428.jpg
http://i413.photobucket.com/albums/p...3122008429.jpg
hi there
wasn't sure if its a normal thing, but bought a 2nd hand euro, and when the roof lights (spotlights where you have the compartment for your sunglasses), is set to 'door' only one lights on (the drivers side).
They both work fine manually by pushing it in and out, but the door only works for the rear and drivers side spot light but not the front passenger spotlight.
(94 euro luxury)
thanks
Hey guys I thought I should jump in here,
I have changed the following to LED in the Euro
- Brake Lights
- Tail Lights
- Blinkers in the rear
- 12 SMD boards for all interior lights, front and back
- Front parkers
- Rear License plates lights
- Both front door courtesy lights
The only normal globes left in the car are dash and front headlight blinkers :)
The car looks like a footy stadium at night, and they are all MEGA bright.
A bit of a stupid question, but how do you remove the "covers" for the rear license plate lights? I need to replace the LED that came with the car as it seems to be blown and I can't figure out how to get the plastic cover off.
hey mate, you need to pry i think 3 to 4 clips. so use a flathead with a piece of cloth over it and pry out the clips and then wriggle the case off. check your manual if you have it
Sweet as. I might be doin similarly too.
You can also get to them from the inside of the boot.
