best is to get a tunable ecu, crome hondata.
change the rod bolts. stock rods can handle 8500 rpm.
The LS rods are the same as B20 rods. Change the rod bearings to the ITR ones. Add headstuds if budget permits.
Really? Hmm, so what was all that other talk in this thread about the advantages of the b18c2 head?
Highjacking topic now but, if I'm building a high power b18c build, should I look into getting the type R head and doing the cams for that etc?
Someone told me the b18c2 provides much higher compression etc?
I have no idea? I'm asking not telling...
Just looooking for adviceeeeeeeeeeee yooooooooooooo!
im not sure how much comp it'll raise. either 0.7 or 1.7
Ok so dose that mean for overall use if your going to be port/polishing, cams, springs etc etc the head will be better for P72 or P3 XD
pretty sure its to do with the different size and shape of the quench pads on the two different heads. a gsr/b18c2 head will raise the compression slightly because of this characteristic.
But does that make it a BETTER head to work? ???
Worked Pr3 vs a worked P72 = Worked Pr3 wins.
