basically i have a integra vti-r b18c2 and since my block crackd from the acident, i bought this type r block, now since i gotta bore out the block i can't use my original pistons. so im going with 81.50mm je pistons, but i only have the standard 1.8 head. not the type r. so im hoping that since my engine only has 10.? compression ratio and the type r has 11.5, it should bump up the power to somewhat similar to a type r engine. also my ecu is a standard p72., ive seen this site called http://www.pgmfi.org/ and they program ecus. so i wanna see if i can incress the fuel since im incressing the compression ratio from standard 81mm @ 10.1 cr to 81.50 je forged 81.50mm @ 11.5 cr....
tell me if im doing anything wrong cause im new at the b series engines.
