u gotta screw it off dont put any down pressure on the screw coz it will just slip back in ...
once u get it a bit then u can use your fingers to unscrew the rest
hope it helps
hope it helps
hey guys... been chasing s2k antenna for ages and didn't know where to post this.
anyone know where i can get one?
cheers
i chasing some down this week ill pm you
Hey can you put me down for one too please?
yes i woud like one to can pm me =)
I found it very easy to install. the most time consuming part is removing the interior trim.Quote:
Originally Posted by chee
hey stanleym sounds great will look forward to your message.
and thanks :)
Turns out that both StanleyM and I were about to order 10 locustum antennae each at the same time, and in the end we decided that this would be too many to move, so I've just put in my order.
They'll be 7-10 days, and I'll post up a FS thread as soon as they get here, with all details, and walkthrough pictures of my install, for anyone interested.
i would like 1 as well.... pm me when they get in
hey i was wanderin', isnt the antenna from the s2k easy to steal. all ppl have to do is unscrew it then its GONE!!!
i bought a missile switch for my antenna so the antenna would only pop up if u listen to the radio and but i cant get it installed cos they say in doesnt work with a pioneer deck [what i have] for some reason. i hate that fricken 1m long antenna.. lol.
try to contact tinkerbell @ the clubitr, he has about 10 pieces coming in only $67 + Aus delivery or pick up in sydney
this is the link : clubITR
i did the exact same things when i had my old deck its a very easy thing to do...... now coz ur antenna works on the same line as the remote etc... goes on and up when the car gets turned on..... u need to apply the switch further down the track.......
ill try explain this the best i can of maybe include a good old paint pic
http://i48.photobucket.com/albums/f2...untitled-2.jpg
now as you see the remote and antenna are the same until they spilt to go there seperate ways..... the remote wire goes back to the ignition section wheras the antenna goes to the motor to say go up or down (depending if there is power of not)
If you can follow the wire and work out which the antenna one is when it has split from the remote... u attach the switch in that spot.... this allows you to control when u want the antenna up or down even when the radio is on etc.....
What i did to work out which wire was right (this beiing in my dc2) was to look at the wire from where the antenna motor then had a look down the side of the car i think it was the driver side under the carpet ... where u feed rca's etc......
anyway i did that and followed it back to the antenna motor to make sure it was right.... (i was looking for the same wire colour combination......)
then i cut the wire installed the switch and worked great !! since then i changed to the s2000 antenna and changed headunit so no need fore the switch to be inplace....
hope this helps u a lil bit :):):):)
and in answa to stealing the s2000 thing.. they can steal just the antenna bit itself but not the whole base and wiring loom as that is screwed in from under boot..... not many people would know it can be unscrewed either.. but if u got fears unscrew it and put it in ur car when u park somewhere :):)
