that will upset brake balance big timeQuote:
you dun need a really good caliper on the rear coz when you brake there is like 85% of the brake power is on the front.....thats why ppl normally change front brake only....correct me if I am wrong.....the monoblock is far more better then the other one......even the size is a bit bigger....I got a friend witha DA9 with Spoon front brake on.......its from DC2 but still bolt on.....so I reckon it will have no problem to fit a VtiR.....the price about bembo is the GT version....not the normal one......the normal is heavy and not as effective....the GT version is super light and expensive......but Spoon is good too......you get what you pay for anyway....... :D
when upgrading to monoblock, is it necessary to change the break fluide as well?
when swapping brakes yes its good to change fluid. (i think it will start draining when u disconnect the lines from the caliper anyways?
when ever you doing any mod with ur brake.....I mean to change the caliper you need to drain ur fluid and put new one on.....of coz you can leave ur old stuff in and top it up after...but its not the way ppl doing it....and by changing the fluid you can get the best result from the change......correct me if I am wrong......hope that help...cheers...
when changing ANY callipers, it's always BEST to change brake fluid as well....
thanz for the info guys..
wots the best break fluid u can get?
and how abt the break lines? do u need to change them?
brake fluids use genuine one....and you dont have have to change brake lines, but i got mine one change
looks like dba wont be able to supply me with itr rotors in a 4x100.
give me a pm i might able to help you out...i know someone that i can probably source one for youQuote:
talking abt places to get a pair of calipers install in the car, wot is the best places to go?
I go to IS they are very details and careful of their work :thumbsup:Quote:
Originally Posted by R123
