I use Fuchs GTO 10w40.. the performance looks better :)
FEO honda still do the job for me...
I've got a h22a in my accord and i always use motul. No problems here. Very happy with it. :thumbsup:
I use Fuchs GTO 10w40! excellent.. !
i just serviced my car done 2,000kms and oil was already empty... does anyone elses prelude vtec burn that much oil or is there sumthing really wrong with my engine?
If you have previously let your engine oil level drop below minimum, your engine will keep on consuming oil due to the wear on the oil control rings. Another cause of oil consumption is a weakened PCV valve spring which allows too much oil fumes to re-enter the combustion chamber and get burnt.
In your case, check your oil level weekly.
Is it hard to change the PCV vavle spring? and would it also cost alot to change? .. Thanks.
Yeh ive tried FEO but ive notice it burnt quicker.. so now im using Fuchs GTO 10w40 .. Where can i buy these valve springs from? .. Thanks for your help :)
It's a 1-way valve that is held shut using a spring. It's not called a valve spring. Just get it from your dealer or your car parts supplier. They should be universal (at least across Jap cars) as I have fitted the PCV valve from a f22a Accord on to a Daihatsu Terios.
geraus: do you hit vtec a lot?
i vtec every 1 to 3rd always from my driving overall 95% the time i hit vtec :D can that be the reason why im burning alot of oil?
