I've bled brakes on other cars before but none with VSA/TCS/ABS yet, is there anything I need to do extra when changing ie. bleeding the brake fluid in regards to the VSA System that I should be considering?
Nope, same as any other honda with low pressure ABS. Only difference I've seen is that the service manual says to bleed from front driver, front passenger, rear driver, rear passenger. That is opposite to the older Hondas.
sometimes when i brake and lik run over a little bump or the road isnt that smooth it feels lik the brake pads have lik fallen off.....i dont know why. i can feel it through the pedals...its starts to lik shake and vibrate bad. doesnt happen all the time onli sometimes out of th blue. any one have the same problem??
