Quote:
Originally Posted by jdmTYPE R
So do I... Tinkerbell made 120kw atw with stock B20b internals which is running ~9.5:1 compression
I wouldn't worry too much about the power output until you run it at the strip...Quote:
Originally Posted by master_bo_bo
What i WOULD worry about is running 85mm bore on stock b20 sleeves, with 12:1 comp. That is pushing the factory sleeves right to the edge.
What sort of RPM are you taking it to?
8000rpm. Previous owner was taking it to 9000rpm with a worked head. Guess we wait and see.
was the previous owner running that much comp?Quote:
Originally Posted by barefootbonzai
I dont think the stock sleeves are as weak as everyone makes them out to be, I think alot of people just use it as an excuse for the poor tuning they had. High compression should be fine if tuned properly by someone who knows what they are dealing with.
oh well, time will tell. all i can say is all the best :thumbsup:Quote:
Originally Posted by ZeForce
i think it will be fine as from my experience,my mate b20vtec with built bottomend is still running its been over 2.5 yrs now,and also 1 of my mate b20vtec with really hi comp and a fully worked head but the engine was only used at the track and it redlines at 10500rpm and been racing that engine for 1.5 yrs and blow the engine with a crack sleeve,i guess that happen from the hard driving and hi rpm all day long.
Yo Keit, clear your inbox.
Yes he was, it's the same bottom end. Adrian might or might not remeber but his the one that tuned it last year (white ek [EKB20]).Quote:
Originally Posted by ginganggooly
good times kit, but paul still beat you lol! and on a prety much stock B16!
:p :D
james
wait till i fix my clutch first and his car is not stock not to mention his ats itr box and his superlight car
Yeah, I remember... :wave: It had cams too from memory.Quote:
Kit, get a new clutch...
Paul is using a twin plate too, another reason why he axed you. :p
