now with 19" wheels, changing calipers is a good idea. my brakes squeal too, and the dealer said its normal? But it goes away after some repeated hard braking.
with racing pads..... it is not called a BIT noise but damn NOISY. even inside the car, i can hear the sharp noise ALL THE TIME which is annoying in the street
bolt on no mod needed
u can fit this with 18' so I cant find a 19' will take an advantage on changing the brake and again if u after the bling only, just go for it as u can use stock disc with spoom mono but this 3k for the JDM bling, u should just go and buy some JDM rims first instead
Sorry to bring up an old thread, but just needed to know if any mods or changes are required to fit the spoon calipers onto the euro???
The info I have received is that the spoon calipers are direct fit for cl7, but not for cl9. Apparently the disc thcikness are different betwen cl7 & 9?
CL7 being 26-27mm and the CL9 being 29mm therefore caliper does not fit over the stock or cl9 discs.. Can anyone confirm??
