no,some models are under the glove box,but yours Im fairly sure is above the hood release lever,I removed one from a DC2 recently & I should imagine it would be similarly placed to yours.Quote:
Originally Posted by XP02ED
Get down near the lever & look up under the dash u should be able to see it.U might be able to test it without removing the plug or relay itself if u can see what your doing.
Heres a pic of where mine lives ,It should be mounted up where u see the wires coming from.
http://i58.photobucket.com/albums/g2...G_1255_1_1.jpg
Also below u can see the 2 yel/blk wires joined to the same pin(2nd pin from top left) & u should be able to touch your tester on the exposed metal of the pin from underneath without removing anything as u can see the metal of the other pins as an example.If u cant reach it u'll have to pull it out to test.
http://i58.photobucket.com/albums/g2...G_1256_2_1.jpg
