ok i'll try that... hmmm... if it doesn't click does that mean i'll need a new iacv?Quote:
Originally Posted by CRXer
and if it clicks does that mean it works...
thanks
thanks
click=:D
no click=:(
lol thanksQuote:
dont forget to get the ECU code for me
oh yeah i had a look at the outside case of the ecu... and there was no code or barcode/sticker... where else to look?
should be another sticker on top of the connector block(thing the plugs go into),u might have to remove the lid to see it properly.Quote:
Originally Posted by kraftycuts
Unless u guys are talking bout the software revision number? Can u get this info off the barcode or do u have to read it off the ROM?
err... not sure man... i'll open it up and see if i can get a model number.
take a photo of it
no probs. will do it tomorrow
hey dudes... got more probs with the car...
k the eg threw an engine code 23... which is the knock sensor... this was done in the morning ... after i drove it to hanny's to get a check up... the engine light was on but after i attached the wires to pull the code up again the light just kept on without throwing codes?
i notice that when i turn the ignition switch on theres a poping sound from behind the cluster or near the fuses, is this normal?
ok second problem... when i drive the eg cold the car seems to work fine... but after the temp gauge starts working (theres a lag in the gauge needle rising) the engine light turns on and the car lags like hell. when i press the accelerator and let go to change gears the revs rises a few hundred then drops???
ok the above is what i have noticed so far... i know its alot to ask but has anyone come across this?
p.s. what does a knock sensor do... i know it detects knocking in the engine but whats knocking? <<< noob question
primary o2 heater might be the fault
Knock is the resonance in the pistons,rods,bearings that is caused by your fuel igniting by something other than the spark plug.Examples would be intake air too hot ,sharp egdes on piston reliefs gettin hot,carbon deposits gettin hot,etc & igniting the fuel seperately to the spark.The meeting of the multiple explosions in the bore causes the resonance & u get that metal "knock" sound.ECU detects knock it retards the timing.
Did u use shielded wire on the knock sensor feed to the ecu out of interest?
Sounds like u might have got your ECT sender(to cluster guage) & your ECT sensor(to ECU) mixed up.
The sender gives a lower reading at normal operating temp than the sensor & the ECU would be making fuel compensations cos it thinks the motor is running hotter than it actually is.Would also explain the delay on the temp guage operation cos the sensor comes down from a much higher reading than the sender.Could also explain the pop behind the cluster cos your guage is tryin to go lower than its meant to.
Thats my uneducated 2cents+GST anyway,I'll send ya an invoice.
