That is why we have Dyno Days... Same dyno, same day... no arguments :D .... (Minus the fact the temperature changes throughout the day)
You're thinking about tractive force. That's the raw figure measured by the rollers.
Power at the wheels (hp) = Torque at the wheels (lbf.ft) (corrected for gear ratio) x RPM/5252
This is used to calculate power at the wheels on the dyno. A dyno can't measure power. It measures torque put down on the rollers (which have a known resistance) and then calculates the power from it using the engine RPM at each point.
I didn't realise that the dyno used engine rpm to calculate outputs, I assumed it was using roller speed vs tractive effort and whatever calculation is required to plot power.
So when the operator calibrates engine RPM vs Speed on the dyno, its going a little deeper than just changing values on the graph?
