Well, mine pulled 112.6kw on Dyno Dynamics when my car had 3000kms on it with the current mods.
What is I/H/E? I'm a newbie to tuning and not mechanically inclined, but I would appreciate suggestions on what to consider and how much to spend if I wanted my 04 Euro to sound really good. What's involved? Does it mean simply replacing the mufflers to something like Fujitsubo?
Also, from the discussion around headers, I think I'll give this a miss for a 10kw gain.
Thanks.
My stock auto made 111.8kw atw on a dyno dynamics in summer. It was certainly the highest auto stock figure I've seen but all other cars on the day did normal figures that matched the mods so I don't believe the dyno was "off".
I still think the auto is under rated. It's no track demon but to most speeds on normal roads they do pretty good.
If you want sound, you can have it loud all the time or loud only when you apply full throttle. If you want it loud all the time, change the exhaust (cat back would be nicest). If you want it loud only at full throttle, go CAI or SRI.
BTW, it is not about peak power gains. If you look at the dyno, it's definite gains throughout the RPM range. This is better than what a Hondata reflash gives you!
why would you want noise without power?? rice....
There was at least S2000 anjd a couple DC5R's but can't remember the figures. They'll be in the Past events QLD Dyno day thread. I'll have a look when I get a sec.
On the thread side, will the toda's fit an auto as I recall Hondata needed a slight change for their headers on an auto (hence more delay)?
The JTune headers were custom made with custom flange locations, cat length and exhaust length (hence their headers being not compatible with aftermarket or stock systems).
The other aftermarket headers from the US fit both manual and auto, so I don't think the Toda will have fitment issues with the auto. The difference with the auto is an additional vibration damper located somewhere around the subframe.
