A straight through single outlet 2.5" should flow better than a 60mm being split into two.
Some guys in the states are running 2.5" single systems and making over 230whp on the k24. The peak power of a single outlet 3" system is usually 5-10hp more than a 2.5" system. The only reason you'd run a 2.5" system on a k24 is if you're a bit worried about noise levels (trust me, even a 2.5" exhaust is pretty loud), or can't have the car tuned to take advantage of the extra flow. Generally speaking the k20/k24's do better with a 3" system (but it also helps if you have a header with a large collector that can take advantage of the 3" diamtere)
Euroaccord13, what was your previous setup? I'm suprised a skunk2 dual exhaust would outflow a single outlet exhaust? Isn't the function of a dual outlet exhaust to reduce noise (exhaust gasses pass through two end mufflers)
In relation to cams, with a k24a3/k24a2 you can use cams, valve springs and retainers that are designed for a k20a2 you just need to use some k20a2 spring seats.
