This was taken from http://customwheelsmarket.com/, further reiterating Deano's post..... Does anyone know what the seat of dc5r rims are??
LUG NUTS: It is critical that the lug nut matches the thread diameter, pitch and seat, otherwise the installation will be improper, and may result in damage to your wheels and could cause a dangerous condition. The three basic types of lug nuts are: conical seat (60 degrees taper "acorn" and "bulge"), mag or shank style, and spherical or ball seat. Thread diameter refers to the diameter of the stud measured across the shank at the outer edges of the threads. Thread-pitch means either the number of threads per inch or if metric, the distance in millimeters between threads. The Seat means the area on the wheel where the lug nut will clamp down.
Warning
Never use a conical seat lug nut/bolt on a mag or shank type lug seat and never use a mag or shank type lug nut/bolt on a conical seat. The two are not compatible and if installed incorrectly, the lug nuts may lose torque, possibly resulting in wheel loss or contributing to damage or injury. In addition, spherical or ball seat lug nuts/bolt must be used with spherical or ball seats. ONLY USE THE TYPE OF LUG NUT/BOLT COMPATIBLE WITH THE TYPE OF LUG SEAT.
