Turn headlights on then pull the windshield wash lever and voila!
Maybe it's broken...or maybe they're not even headlight washers at all =X show us a pic?
add water!! :P
Yeah it uses the same tank.
Well..if you turned on headlights and pulled the windshield washer on and it doesn't work..then i'm assuming there's some issue with it...might be best to get it checked out..however might be a waste of money =/
Try again? maybe something is stuck
looks cool when doing also but sprays more then needed, meaning that it sprayed all over my bonnet then just my headlights
before i took that pic... it wasnt popping out properly... just wriggling around... so i added water and it was worked...
is yours moving at all? can we see a pic of it on your car?
Just tried my headlight washers today, just flick the lights on and pull the lever and water should start spraying...
The jets are really crazy as they wet the whole bonnet which is pretty out of control.
lol mine wasnt working either.. until i had to replace my bumper from a cosmetic damage.. and when it came back from the shop.. it worked.. voilaa haha
