Software update was done at Gladstone Motor World, no sign of the pinging problem after 1200km since the update. They will also be changing the Knock Sensor when available.
I think it might be something to do with ECU program tweaks to the fuel trims and ignition timings under certain engine conditions that caused the sound.
Updated knock sensor will likely improve the ability of the engine management to determine when those conditions occur and avoid it.
- HZ
No post since August 13 is this correct or has the site been stopped????
Take the number of Euros sold and then work out how many have pinging type sound issues...small percentage and most have probably posted on this site so we cant expect too many more posts!
Cheers
51 pages so far.
I believe now that the fix is being released, albeit slowly at first, that this problem will be history is several months if it is as successful on all cars as it has been on mine. While i do agree it has taken longer to solve than most of us would like, these things do take time to solve properly. The great news is that it has no effect on the drive ability, performance or economy of the car.
Yes, there has been 51 pages on this subject, but if we look into it further those 51 pages have been made up with postings from 94 Ozhonda members & if we break it down even further, postings directly relating to the pinging issue would max out at approximately 60% in total. The remainder are on slightly different subjects or members just asking questions. I would also suggest that a percentage of those 94 contributors don't own a cu2 (moderators excepted) & are trying to compare their CL9 to the CU2. That is like comparing apples with bananas. So in reality it makes no difference if there are 5 pages or 5,000 pages on a given subject, it is what is in the content of those pages that is relevant.
I have now done about 2000km since the software update & couldn't be happier with the result. What difference the knock Sensor will make when it becomes available is yet to be seen. In saying that, i do think i heard an ever so slight ping for about 2 seconds the other day, (it was on a steep 2nd gear climb with A/C on) but it was so brief & minor I can't be absolutely certain about it.
um...i dunt think u should worry about the pinging noise all new euros have it...atleast most.
My euro is now 20000K and the pinging stopped. It usually stops at around 15000K.
The service manager at my local dealer said that all CU2's ping but most owners don't notice and that they will only fix the cars whose owners complain about the pinging. So, if you buy a second hand CU2, make sure you check that it's been de-pinged as it would be likely that it won't have been.
