you need to bargain harder...i got a better deal than that...but doubtful that they'll go all the way down to 30k...
and it's probably better to bargain with andrew coz he's the one who actually owns the business...
i second what sai_ANN said.
especially AUD is stronger now than last year.
i think AUD to Yen is 102 now....definitely bargain harder.
someone buy my strut brace so i can get kpro....cmonnnnnnnnnnnnn ha ha
got some tein s-tech springs fitted today as i got a deal for them where i don't have to pay anthing lol. springs are from japan and for ep3 so correct springs, car at the front went down 25mm like they said but at the back went UP 10mm. Got the whole suspension place stumped, had everything in and out 3 times and got no idea, what you guys think ha ha
up 10mm?! geez that must suck. hopefully it will settle somewhat? maybe go sit in the boot for a bit and help it along.
ha ha yeh gonna let it settle but seriously doubt will settle and drop 25mm to what it should be.
Is it being measured on a level surface......before and after?
I have Spoon springs and they're perfect for what I wanted. About 15mm all round!
yeh all level, done by proper suspension only workshop so no schoolboy errors like if i did it ha ha. it's weird what's going on with it
Not much you can do to stuff up a sussy install in an EP3. Pretty straight forward. Maybe is just the way the springs are designed?
Any side on pics? What are the measurements between the centre of the wheel to the lip of the guards. Maybe I can give you some comparison measurements off mine!
Car doesnt sit much lower, but its alot stiffer and goes well with the stock shocks!
Just for you i-vtec :)
typercivic have a look at my height! Post #658
Nepolian, thanks for that, would have gotten pic of mine but it's pitch black atm. Front looks about the same, as mine will settle about 3-5mm but your rears are how mine should be.
this is straight off tein spec sheet that was with springs, stock height is 345 and should go to 325, but mine went to 355 when we measured at workshop. fulcrum are confused as well but know it's not right, they said let it settle but it obviously won't settle 30mm but it was 4:45pm in queensland and I think they just wanted to go home so said that ha ha bastards
what do you have to adjust your camber front and rear?
