no, pretty sure inlet to cat is stock 1.75 or near there.
what headers u using 'thescotty'
xforce..but im not sure if it was off a stock or aftermarket exhaust system
factory headers pipe is 2 1/4 inchs but the flange is smallerits more like 1 3/4 inch having said that the pipe goes as big as 2 1/2 inches on the OD of the pipe at the flange where it bolts to the CAT
where abouts r u measuring from im assuming ur measuring from the ID of the headers u have
sry for bad quality pics but took it on my fone will have good ones when i get the data cable... its what ive been doin i got gauges to but i need the other camera...
extractors fit good, on the low down 2 of the bolts on the far left that hold them to the engine are snapped off (no wonder there has been a ticking noise :s) now have to get new thred! and the full exhaust system this week:) cheers for the help guys.. also do xforce ones usually come with the oxygen sensor on one of the pipes closest to the engine cause we had to re wire the sensor to be longer.
piston sparking wtf?????? get off the drugs
u should b able to drill it out and either helicoil it or u mite find itll still b ok
i have one broken on mine to
nah they usually dont come with oxygen sensors
hey guys just wondering what type of exhaust system you think this is, it was off a integra DA9 and it is fatter piping all round then the stock one? any ideas, sports or whatever? cheers guys!
Pic 1:
http://i280.photobucket.com/albums/k...y89/image1.jpg
Pic 2:
http://i280.photobucket.com/albums/k...y89/image3.jpg
sorry bout there pics, hard to get the drift of them! cheers
fairly sure its off the first of the da9s there different to the later model ones
taht doesn't look like a stock b-pipe..mostlikely custom made..and the way the bend is done...looks like custom made by exhaust shop
so is it stock? Cause its fatter then the stock das also has a different tip.
any performance like do you recon its a custom made sports exhaust?
