tein springs are around 1.5" lower... its mainly cos of the after market exhaust i think that it sits pretty low
clearance looks like 10cm
if we have a photoshoot please let me know cos im a little bit of a photography guy lol
anyone here knows how to pull the door trims off? need to adjust my window glass on the reg, they r a bit loose atm.
thx guys
random question boys, just wondering if you c-package boys have a light/s near your windscreen (so you can see your cup holders and shit at night) or is it just the middle lights which turn on when your doors open?
If u mean map lights for driver and front passenger, then yes we have a pair near the windscreen.
Push the silver trim off from the door handles, there is a small hole at the base where u can use a hex key to push the silver trim out. Which then exposed some screws. U need to undo those screws, then pull off the black trim near the mirrors. Do that very carefully as the clips snap very easily. Then check if there is screw near the silver door catch thing, undo them if there are some and I should be able to pull the door trim off.
Pull from the bottom and side, there should be a few clips around and make sure u don't damage them. Then u should be able to lift the trim off the top. Also make sure the door catch is clear. U will then need to unplug the power window plug and the trim should now be free.
Ey anyone got defi gauges?? I'm looking to get some when I go hk next week... Any idea if tere is a defi hood cover for ep3??
